IR 210S Change language
  • banderas
    • Dec 2007
    • 23
    Hi all,
    I am a trained technician for Ricoh but in my life I did work with many Canon machines like NP1550, NP38..., 6317, 2120, 6330, 6045.
    I got one IR 210S with french language (on the display) and i want to switch it to English. Also, if it is posible, can i get a service manual for this machine. Thank you all.
    banderas
  • alex@wocltd.com
    • 430
    do you mean ir2105 ?
    most languae problems are the same -dump everything and it will revert back to the default(normanlly english) if thats not the case via sst load up whatever lan you what -in your case english
    • banderas
      • Dec 2007
      • 23
      No it is IR 210 S
      Like i said i am not trained for IR digital Canon.
      The machine is without printer controler.
      tks
      banderas
      • banderas
        • Dec 2007
        • 23
        according to the service manual i have to flash machine.
        can i get from someone software for that?
        tks
        banderas
