ir 5870 partial light copy
  • Apach
    • 157
    [Misc] ir 5870 partial light copy
    Hello,
    I tried to find with searching but I'm too old for it
    ir5870.pdf
    I'm replaced primary and secondary corona, ITB and primary and secondary transfer rollers (after 500k copies). Results is the same.
    Bright part of the copy appears when printing and copying. B/W or colour give me same result. Do you have any advice on what else could be causing this problem?
    thanks
    There is no stupid question, just stupid answer
  • canonbundy
    • Jun 2012
    • 607
    Re: ir 5870 partial light copy
    Originally posted by Apach
    Hello,
    [ATTACH]20531[/ATTACH]
    thanks
    In the IRC5870 the black Dev unit is located at the top of the Drum unit and opposite the Cleaning unit check both for an obstruction ie a piece of paper.
    • jaim3naps
      • Feb 2013
      • 29
      and also check the laser scanner dust proof glass for possible dirt...and the contacts too.
      • tenatal
        • Aug 2011
        • 35
        does copier gives some error code after certain number of copies/print?
        it looks like that toner is not properly pouring into developer/toner unit,for which copier also give error code like e0020
        • Apach
          • 157
          No errors. Over the weekend I will dismantle developer.
          • teckat
            • 16084
            Hello,
            thanks
            what paper size is that example ??
            cross-feed (front to back of printer)
            or paper feed (lead edge to trail edge)
            Check the grounding plate at the rear of the ITB assembly.// should be touching /secure all the time
            • Apach
              • 157
              Size is A4 . Light spot is the same position on A4R. Grounding checked and is OK.
              • teckat
                • 16084
                Same spot \ differant sizes / glass & prints \ no movement on continous / = LASER
                • Apach
                  • 157
                  I have one laser unit in the reserve, so I'll try to replace him. Easier than dismantle developer.
                  I will turn the result on Monday. Thank you all for your help.
