E027-0400 in IR advance color 5035
  • DANIELCANON
    • Jun 2011
    • 187
    Hi everybody, the machime error code indicates, No black color on test 10.
    Best regards.
  • teckat
    • 16083
    Re: E027-0400 in IR advance color 5035
    Error code E027
    items to look at
    1- Check if the black toner bottle is seated correctly in position > if not it will result in the error code.
    Removing the black toner bottle and manually opening and closing the end cap along with re-seating the bottle may resolve the code.
    2-The gear stripes out do to friction in the developer assembly. Replacing the gear may not resolve the problem. Open the developer and check for toner clumping and for a stuck auger. Rotate the auger by hand with the cover open and see if the toner moves freely.
    Solution :
    It has been found that the D cut portion of the drive gear can strip out and not allow drive to the developer. The drive gear is a X shaped gear.
    The gear part number is FC8-4338-000.
    • DANIELCANON
      • Jun 2011
      • 187
      Ok, era exactamente el problema ya se corrigio.
      No estaba girando la unidad de revelado negro.
      Gracias
      • teckat
        • 16083
        Gracias
        • bernyolvera
          • Mar 2019
          • 1
          • Pete from Prescott
            • Feb 2012
            • 26
            Here's what I found. Not sure if the above techs fixed it so thought I'd send this.
            • Code: E027-0400
            • Description:Error in supply with Bk Developing Assembly
              Failure in detection about the changes of ON => OFF => ON with the sensor which detects a full rotation of the supply screw within the specified period of time.
            • Remedy:
