Custom Main Menu Wallpaper
  • slamanna212
    • Jan 2013
    • 14
    How do i upload custom wallpaper to a imageRUNNER ADVANCE?
  • teckat
    • 16083
    Re: Custom Main Menu Wallpaper
    ---customize the wallpaper.pdf
    For All imageRUNNER ADVANCE Series, the selection of predefined wallpaper images can be selected at the copier screen as outlined below.
    To Change the Wallpaper settings for the Main Menu, execute the following.
    1) Select Settings/Registration.
    2) Select Login and enter System Manager ID and System Pin.
    3) Select Login.
    4) Select CLOSE.
    5) Select the Silver Box on the top right of the screen with the red strip.
    6) Select Main Menu Wallpaper Settings.
    7) Select a background wallpaper.
    8) Select OK.
    9) Select Logout.
    To Change the Wallpaper settings for the Quick Menu, execute the following.
    1) Select [Quick Menu] on the copier's display.
    2) Select the silver box with the red strip on the top left of the display screen.
    3) Select [Set Wallpaper].
    4) Enter the System Manager ID and System PIN.
    5) Select a background wallpaper.
    6) Select OK
    7) Select Logout.
    • grandmaster
      • Aug 2011
      • 9
      Setting uo of customized wall paper ia available for version 2 machines i.e. iRA C52XX series not with iRA 50XX.
      Procedure is defined in user manual
      • teckat
        • 16083
        How to customize the wallpaper for imageRUNNER ADVANCE Next Generation Devices
        SEE PDF---------imageRUNNER ADVANCE Next Generation Devices.pdf
        • johnyb
          • Feb 2011
          • 167
          Hi
          Anybody Idea how to load a custom wallpaper onto a Gen 3 lll product?
          The bgimport procedure works on the Gen 3 l series & the Gen 3 ll series but doing the same procedure brings up the same page but says access is restricted, I cant seem to find any info on the canon tech website that refers to a different procedure...
          Any help gladly appreciated!
          • teckat
            • 16083
            Originally posted by johnyb
            Hi
            • johnyb
              • Feb 2011
              • 167
              Thanks for the info and for getting back to me Teckat
              I cant seem to see how to load a custom logo, it just referneces that this must be done from servcie mode.
              Restricted from displaying this page.
              • teckat
                • 16083
                How to Customize Your Canon Copier Background For Main Menu
                How To Customize Your Canon Copier Background for Main Menu
                I. Uploading the custom wallpaper to the device
                1. Enter [http://<device IP address>/bgimport] into the address bar of Internet Explorer.
                Note: The only way to access this function is by typing this address into the URL bar.
                There is no button within the RUI. As a reminder, this function must be turned on within service mode.
                You will not see this screen unless you are in service mode.
                In service mode;
                COPIER
                OPTION
                FNC-SW
                SVC-RUI (In page 5 or 6, I think)
                Set a number to this setting. Then use that number on upload.
                2. Click [Browse] to find the image file that will be imported to the device.
                Note: Only files that meet the specific pixel and naming guidelines can be uploaded.
                Below are the image requirements:
                Dimensions (Width/Height) File Type (Naming Convention)
                3. Select the Image File Name.
                4. Click [Open]
                5. Enter the password.
                6. Click [Start Importing].
                Note: This password is assigned while the device is in Service Mode. Please work with your service technician to obtain the password.
                1. Click [Ok].
                2. Restart the Machine.
                Note: The next step is to make the image accessible to end-users from the Main Menu Wallpaper Setting interface. You must restart the device for the changes to take effect.
                II. Selecting the uploaded custom wallpaper from the UI
                9. Touch [Settings/Registration] button to log into the device as an Administrator.
                10. Touch [Log in].
                11. Enter the required information and touch [Log in].
                12.Touch [Close] to exit the Settings / Registration screen.
                Note: Steps 1-3 are only necessary if you are not automatically logged in as the Administrator
                13. At the Main Menu Screen, touch the [User Interface Settings]icon.
                14.Select [Main Menu Wallpaper Setting].
                15.Touch the [page down] button to go to Page
                16.Touch [Other Settings 1].
                17.Touch [OK].
                Note: Note: The pattern, brightness, and design of the image affect how easy the LCD panel text can be read. Your customers should keep this in mind when designing custom backgrounds.
                • johnyb
                  • Feb 2011
                  • 167
                  Thanks Teckat
                  I've done this many times on the Image runner advance 2 series and the Gen 3 MKl & ll but for some reason on the MKlll devices I get the message saying the web page is restricted despite the SVC rui being set to any number....
                  I think I will have to contact Canon
                  • 20 year tech
                    • May 2014
                    • 577
                    This may help
                    TP19 080a.pdf
                    • johnyb
                      • Feb 2011
                      • 167
                      Originally posted by 20 year tech
                      This may help
                      [ATTACH]42937[/ATTACH]
                      Thanks 20 year tech, got sorted with it now with that info off you.
                      looks like the procedures the same except for two things... hm before bgimport = hmbgimport & the reduction of the required file size..
                      Many Thanks
                        • 8146
                        The procedure to perform this task is far less complex on the last two Toshiba generation of copiers. Five keystrokes including Admin log in.
                        In fact, I lead with the easy ability of Toshiba copiers to fully customize the LCD panel.
                        • johnyb
                          • Feb 2011
                          • 167
                          Good, I'm really pleased for you!, but there are much better products on the market than what Toshiba offer, for you to lead with in sales.
                          Yes it may be easier on an Toshiba to customize the screen than on a canon device, but I'd rather own or work on a canon product any day of the week as opposed to a Toshiba, the build quality of a Toshiba is poor in every way, terrible to work on and poor output quality.
                          Canon products are solid ,robust, reliable products , and excellent colour quality (on the colour range) ,and what they do, they do it well.
                          • bodle
                            Hi I was just wondering, are only certain models supported for custom BG imports?
                            • yogapratama1006
                              • Aug 2021
                              • 2
                              anyone know how to change custom background for image runner advance 40/42 and 60/62 series?
                              ive found machine from china with customized background before
