iR5075 Tray 3 paper out
  • copicatt
    • Nov 2008
    • 366
    This is a machine that was purchased from another vendor, so it's new to this company. Anyway, tray 3 doesn't show the paper size nor detect paper. "flashes" like it's out of paper.
    1. the tray does lift and stops at the top like it should (wondering why it stops if it doesn't detect paper)
    2. swapped ports 3 and 4, no change, still tray 3 doesn't detect.
    3. swapped cassettes to see if there was an issue, no change.
    Is there some sort of sensor adjustment on these that can be ran? Anyone experience this? I've had them not lift before, but that was different.
    Thanks for the info.
  • teckat
    • 16083
    Re: iR5075 Tray 3 paper out
    make sure that the draw #3 is not set up as disabled --in Auto Paper Selection1) Press the Additional Functions key.
    2) Select the Common Settings option.
    3) Scroll until you see the option for Drawer Eligibility for APS/ADS.
    4) Depending on which model imageRUNNER being set, some of the following options are available for selection: Copy, Printer, Mailbox, Fax, and Other.
    any messages on LCD ? flashing on tray icon
    no add paper>even without paper in tray
    1-it detects both cassettes because it lifts/= tested=yes
    2-swapped pick-up units 3>4= # 3 bay keeps the issue with # 4 swap/ tested=yes
    3-it just will not show a paper size or load paper
    there is a paper size adjustment/cassette width adjustment in service mode
    COPIER>FUNCTION>CST>C3-STMTR,
    COPIER>FUNCTION>CST>C3-A4R,
    COPIER>FUNCTION>CST>C4-STMTR, and
    COPIER>FUNCTION>CST>C4-A4R
    This model requires paper to be in the tray in order to perform the adjustment.
    look in this below and make sure all set to plain paper and not custom
    Additional Function > Common Settings >< Store Paper Type>
    Set the paper type to Plain
    • copicatt
      • Nov 2008
      • 366
      Thanks. Yes, the tray icon is flashing as in it is out of paper. Even after lift....and no paper size pops up when inserted.
      • teckat
        • 16083
        SUSPECT a internal connection problem on printer frame side for #3 area bay connector
        or
        CHECK
        Address /bit/ Description Remarks
        BIT-----------------BIT
        15<<<<<<<<<<<<<<0
        P001
        BIT-
        0 -manual feed paper sensor signal 0: paper present
        1 -registration paper sensor signal 1: paper present
        2 -right deck retry sensor signal 1: paper present
        3 -cassette 3 paper sensor signal 1: paper present
        4 -vertical path 3 paper sensor signal 1: paper present
        5 -cassette 4 paper sensor signal 1: paper present
        6 -vertical path 4 paper sensor signal 1: paper present
        7 -right deck paper sensor signal 1: paper present
        8 -vertical path 1 paper sensor signal 1: paper present
        9 -left deck paper sensor signal 1: paper present
        10 -vertical path 2 paper sensor signal 1: paper present
        11 -outside delivery sensor signal 1: paper present
        12 -inside delivery paper sensor signal 0: paper present
        13 -not used
        14 -claw jam sensor signal 0: paper present
        15 -left deck pull-off detection signal 1: paper present
        P002
        BIT
        0 -cassette 3 retry sensor signal 1: paper present
        1 -cassette 4 retry sensor signal 1: paper present
        2 -left deck retry sensor signal 1: paper present
        3 -reversal sensor 1 signal 1: paper present
        4 -right deck limit sensor 1: paper present
        5 -duplexing pre-registration signal 1: paper present
        6 -duplexing horizontal registration sensor signal 0: paper present
        7 -reversal sensor 2 signal 1: paper present
        8 -write check sensor signal 1: paper present
        9 -developing assembly toner sensor signal 0: toner low
        10 -hopper toner sensor signal 0: toner low
        11 -duplexing paper sensor signal 1: paper present
        12 -fixing web length detection signal 1: web absent
        13 -fixing output sensor signal 0: paper present
        14 -shutter HP signal 0: HP/set position
        15 -waste toner feedscrew signal 0: lock
        P004
        BIT
        0 -cassette 3 size detection signal 0
        1 -cassette 3 size detection signal 1
        2 -cassette 4 size detection signal 0
        3 -cassette 4 size detection signal 1
        4 -fixing shutter thermistor overheating detection signal 1: overheating
        5 -fixing sub thermistor overheating detection signal 1: overheating
        6 -fixing main thermistor overheating detection signal 1: overheating
        7 -accessories power supply fan stop detection signal 1: stop
        8 -not used
        9 -HVT cooling fan stop detection signal 1: stop
        10 -circulation duct fan stop detection signal 1: stop
        11 -hopper toner sensor connection detection signal 0: connected
        12 -developing toner sensor connection detection signal 0: connected
        13 -shutter set detection signal 0:HP
        14 -relay OFF detection signal 1:OFF
        15 -fixing inlet guide solenoid connection detection signal 1: not connected
        P008
        BIT
        0 -manual feed door open/closed sensor signal 0: line
        1 -right deck paper level sensor signal 1: paper present
        2 -right deck pull-off sensor signal 1: paper present
        3 -left deck paper level sensor signal 1: paper present
        4 -left deck limit sensor signal 1: paper present
        5 -cassette 3 paper level sensor signal 1: paper present
        6 -cassette 4 paper level sensor signal 1: paper present
        7 -not used
        8 -cassette 3 open/closed sensor signal 0: open
        9 -cassette 4 open/closed sensor signal 0: open
        10 -registration clutch ON signal 0:ON
        11 -right deck open/closed sensor signal 0: open
        12 -left deck open/closed signal 0: open
        13 -lower right door open/closed sensor signal 0: open
        14 -bottle cover sensor signal 0: open
        15 -front door open/closed sensor signal 1: open
        P012
        BIT
        0 -circulation duct fan (half-speed) ON signal 1:ON
        1 -circulation duct fan (full-speed) ON signal 1:ON
        2 -drum heater ON signal 0:ON
        3 -power supply fan ON signal 0:ON
        4-5 -not used
        6 -cassette 4 lifter motor ON signal 0:ON
        7 -cassette 3 lifter motor ON signal 0:ON
