iR2520 network card issue
  • Will1
    • Mar 2013
    • 17
    Hi All
    Please can someone perhaps shed some light on an isssue i have with an iR2520? This machine will not print , ping only copy. Before replacing the main controller I wanted to know if there is anyway I can reset the network card via service mode?
    Regards
    Will
  • vamoursly
    • Sep 2011
    • 273
    Re: iR2520 network card issue
    To verify you can ping the IP address on your LAN / network?
    First port of call, check the driver, UFR / PCL / PS - make sure its not set to work offline in the printer properties
    Come back let us all know
    V
    • Rachid.Akli
      • Oct 2011
      • 595
      Originally posted by Will1
      Hi All
      Regards
      Will
      Have you installed the right driver (UFRII). PCL driver is optional.
      Rachid.
      "Find a job you love and youโ€™ll never have to work a day in your life." Nagy's father
      • Will1
        • Mar 2013
        • 17
        Hi
        Sorry
        That should of read i cant print or ping. I can only copy.
        • vamoursly
          • Sep 2011
          • 273
          Man, were do you start;
          Does your network use TCP/IP?
          Have you configured a valid static ip address on the copier that will at least work on your local subnet?
          Is it plugged into a live network point, is there an activity LED on the switch / hub / router were it terminated?
          I would try these very basic things first to ensure connectivity, when you can ping it - then we will talk about UFR drivers
          Best of luck
          V
          • Ron314
            • Apr 2013
            • 97
            Just to add onto Vamoursly's train of thought, when you plug the copier into the router does it show connectivity? Usually a little green light on the router. Usually a dead board won't get past this test.
            Ron314159265
