Error 00061-00001 ir 6570
  • bluesky2000
    • 95
    hi all
    i have ir 6570
    it's work and copy about 60 sheet and then i get error in the screen 061-0001
    i clear the error
    but But it's shows again
    please help >>>>
  • HP:guy
    • Feb 2013
    • 279
    Re: Error 00061-00001 ir 6570
    Potential control error.
    Replace the potential sensor unit.
    - Replace the laser scanner unit.
    - Replace the DC controller PCB.
    • Simons
      • Jun 2008
      • 490
      It could go away if you polish the drum. If you do not polish the drum you can get these e61 error codes on this and the 5000. Do that first , if that doesn't work , turn off potential control so customer can run and order a new sersor. You will need the tool to install it.
      • Ron314
        • Apr 2013
        • 97
        E061 There is a potential control error/there is an APC error.0001 As a result of potential control, the drum
        surface potential (VL2) of the background
        is 200 V or higher (i.e., causing a solid
        black image).
        - Replace the potential sensor unit.
        0002 The primary charging output used at time
        of printer output and the drum surface
        potential after laser output is identified as
        being 200 V or more (i.e., causing a solid
        black image).
        Check to see if the laser shutter is even opening when the door shuts, I think I saw that create the same problem on an ir 6570 a year ago, most likely you should (I know this sounds nuts) take off that fan housing that you normally remove to get at the charge coronas, if it has a broken key-pin that actuates the laser shutter door then that's the problem.
        Ron314159265
        • bluesky2000
          • 95
          where can i find this fun
          thanks for help.........
          • bluesky2000
            • 95
            first i do not polish the drum -- i try to replaced it and i checking and i told you what happen
            second - how can i turn off potential control - i have 3 machine ir 6570 -i can use part from any one to solve the problem
            • Ron314
              • Apr 2013
              • 97
              I assume that you meant "fan" and it's inside the front door with 3 screws holding it in place as well as 1 connector. Just replace it with one from your other machines. Though I'm now thinking that it could possibly also be your charge coronas so swap them out as well from your other ir6570.
              If the previous ideas fail to solve the problem then to turn off the Potential control as a previous poster had mentioned, here is the information.
              COPIER > OPTION > BODYSub-item Description Level
              PO-CNT Use it to turn on and off the potential control mechanisms.
              setting: 0: off; 1: on (default)
              • bluesky2000
                • 95
                thanks my friend it's solved
                by replace the drum and corona
                it's work very good
                thanks again >>>>>>>>>>>
