iR 2550 Fax Transmission Level
  • altanderson
    Hi all,
    We are having a bit of an issue with the fax in an iR2550 due to low transmission level. The signal to noise ratio is fine but the transmission level is so poor that it is making some communications fail.
    At the moment we've got a transmission level of -27.9bDm (which is poor).
    Is there any way on the iR2550 to adjust the transmission level via the service menus?
    Any help you can offer is appreciated.
    Thankyou.
