Canon iR c4080 error code E000751-1411
  • rmlantry
    [Error Code] Canon iR c4080 error code E000751-1411
    What is it? How do I fix it? Where can I get a "SERVICE" manual listing all error codes (not just user error codes)?
  • its_just_a_copier
    • May 2011
    • 132
    Re: Canon iR c4080 error code E000751-1411
    E751
    Abnormal condition of the drum unit/toner bottle
    "X" in the following errors shows "X=1: Reading" and "X=2: Writing". "x" shows colors [Y=1, M=2, C=3, K=4].
    00Xx
    Abnormal connection of the drum unit (Abnormal condition on the printer side)
    Check the connection of the drum unit. / Replace the drum unit.
    01Xx
    Write error of the built-in memory in the drum unit
    02Xx
    Data error of the built-in memory in the drum unit
    04Xx
    CRC mismatch error in the drum unit
    05Xx
    Drum unit communication error
    10Xx
    Abnormal connection of the toner bottle (Abnormal condition on the printer side)
    Check the connection of the toner bottle. / Replace the toner bottle.
    11Xx
    Write error of the built-in memory in the toner bottle
    12Xx
    Data error of the built-in memory in the toner bottle
    14Xx
    CRC mismatch error in the toner bottle
    15Xx
    Toner bottle communication error
    9000
    "24V down" was detected during communication with the drum unit or toner container. (The color cannot be identified.)
    Check the power supply output of 24V series on the main power supply PCB.
    • rmlantry
      thank you!!!
      I pull out the toner cartridge, wait half an hour, put it back in and it works for a while. It's a new yellow toner cartridge, so I don't want to junk it, but i don't want to fight the machine either.
      • teckat
        • 16083
        Originally posted by rmlantry
        thank you!!!
        is this an OEM TONER CONTAINER ???/
        how old is Y DRUM ?
        • its_just_a_copier
          • May 2011
          • 132
          Better be safe than sorry. Replace the cartridge and move on.
          • redzventures
            Service Tech
            • May 2009
            • 45
            If you are using unauthorised toner and it turns out to be poor quality toner, it could start to affect your copy quality and posibly cause expensive damage. I agree, you should just bin the suspect toner.
