Canon ir adv C5235I user ID mangement
  • dickiebob
    • Sep 2011
    • 66
    [Misc] Canon ir adv C5235I user ID mangement
    Got a customer with a 5235i, but it could be any machine using id management. Set up so that they can use black print and copy without the need for an id.
    Does any one know if you can set it so you can use the send function without an id?
  • onlyinnewfoundland
    • Apr 2013
    • 235
    Re: Canon ir adv C5235I user ID mangement
    Don't quote me on this but I seem to recall seeing this option in the ID management section of the remote UI. I think it's in a different spot on the machine itself.
    • redzventures
      Service Tech
      • May 2009
      • 45
      You'll probably need to get hold of a service manual which has the whole ID MANAGEMENT settings included. You can find the service manual here:
      Canon imageRUNNER ADVANCE 5235
      i
      You'll need to look at page 181 which covers the ID MANAGEMENT. The manual is a big document (1410 pages or 72MB).
      I'm not sure if I can include the link so apologise if I've broken any rules.
      Good luck
      • iSi
        You can, either allow or prohibit this via "Limit Functions." From the RUI: Settings/Registration : Management Settings : User Management > Department ID Management > Department ID Management Settings and uncheck Send under Limit Functions.
        Will be in a similar location on the control panel.
        Cheers.
          • 16083
          in other iR's With Department ID mode enabled/
          black copies & prints be made without entering an ID and password
          Additional Functions > System Settings > Dept. ID Management > Allow Black Copy/Inbox Print Jobs > On
          & Allow Black Printer Jobs > On
          for your ADVANCED model check under
          User Mode ([Settings/Registration]), select [Management Settings] > [User Management]> [Department ID Management]
          Department ID Management /On, Off*
          Register PIN Register, Edit, Delete, Limit Functions
          Page Totals Clear, Print List, Clear All Totals, Large2 Count Management
          Allow Printer Jobs With Unknown IDs /On*, Off
          Allow Remote Scan Jobs With Unknown IDs /On*, Off
          Allow Black Copy/ Mail Box Print Jobs/ On, Off*
          Allow Black Printer Jobs /On, Off*
