IR 2200 Service Menu
  • youssefK
    Hello,
    I have an IR2200 Copier, i got an error message E000014-0000 and it is refusing to start up. The error was due to an electric problem and is already fixed. I need to enter the service mode in order to clear the error, could anyone tell me how i can enter the service mdode in the IR2200?
    Thank you very much
  • xcopytech
    • Aug 2006
    • 1794
    this is fixing motor fault
    you need to replace main power pcb, fixing motor or dc controller board
    you can not reset this error
    • karthik
      i have a problem with my ir 7200i .i takes more time for spooling when i give visual foxpro documents. pls give me some suggestion to sort it to
      • vandezo
        I don't know
        • 161
        Originally posted by youssefK
        Hello,
        Thank you very much
        *2+8* (*=additional functions)
        copier -- functions-- clear --err
        but, there e014 , so you must check composite power supply, main motor and dc control..
        • amuba
          • 30
          Hello,
          Thank you very much
          Printer Canon and Epson
          problem
          printer canon,epson,hp
          iwan
          RESET CANON,Printer Canon,Printer EPSON,HP Deskjet and Manual Service
