E004-0201, E004-0501 on IR C5185
  • adeyemi
    • 378
    Can anyone kindly help out with some solution for E004-0201 and E004-0501 repeatedly on IR C5185.
    Dgtal
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: E004-0201, E004-0501 on IR C5185
    How many prints have fixing assy?
    • herlin
      • Jan 2011
      • 33
      What have you done already?
        • 16083
        U NEED TO REPLACE THE UNIT --------------are u a tech
        E004 indicates a fixing unit protection circuit trouble.
        • Rachid.Akli
          • Oct 2011
          • 595
          Dear all,
          Replace the fixing unit and do the appropriate adjustments.
          Be sure to execute the following operations in service mode.
          -Clear the fixing delivery counter:
          COPIER > COUNTER > DRBL-1 > FX-BLT-U
          -Execute the fixing belt and pressure belt HP search operation:
          COPIER > FUNCTION > FIXING > FX-UHP-S
          COPIER > FUNCTION > FIXING > FX-LHP-S
          Rachid.
          "Find a job you love and you’ll never have to work a day in your life." Nagy's father
          • adeyemi
            • 378
            New machine, less than 20K prints!
            Dgtal
            • adeyemi
              • 378
              Tested with another fuser and it worked. I want to know how to repair the faulty one, 'cause its still quite new less than 20K prints
              Dgtal
                • 16083
                READ PDF---------TP09 205d.pdf
                did u try to do below for E004 in service mode
                COPIER>FUNCTION >CLEAR>ERR
                5185's are not new printers/ they came out in 2007/
                20K means nothing is FULL COLOR was run at more than 6% coverage
                swapped FIX UNITS will probably pop an E007 Error down the road if u did not do the above posted adjustment
                REPAIR what ?? Temperature issue ?
                u would first need to disassemble to inspect> GEARS & CONNECTORS>
                U CAN NOT INSPECT INTERIOR THERMOSTAT INSIDE BELT
                Did u First check that the Fixing Door has not popped open and closes and locks properly (a typical problem that usually
                goes unnoticed) and retry.
                • adeyemi
                  • 378
                  Thanks friend. What i mean is that this particular machine is relatively new, haven done just about 20,000 prints. I also said that when i put another fixing unit, the machine worked perfectly. Meaning the problem is right inside the fixing unit. That is why i'm wondering what is damaged inside it and if it can be fixed. And thanks for the attachment, i 'll study closely and see what i can get from it. Thanks
                  Dgtal
