IRADVC5030 restarting on its own
  • rayjeek
    • Jun 2010
    • 239
    [Misc] IRADVC5030 restarting on its own
    I have IRADVC5030 restarting on its own about 3/4 way through the booting progress bar. It just continues recyling about 3/4 way all the time. Controller diagnosis done 2+4 result ok. Performed boot check but did not see anyflasshing of light on screen. I have placed an order for HDD anyway. What else is there to check on next visit. Thanks
  • teckat
    • 16083
    Re: IRADVC5030 restarting on its own
    remove & re-seat Main Controller PCB + both Memory DIMMs
    also try--removing the Fax Kit, see if printer the boots up, if up then power off & re-connected the Fax kit
    • rayjeek
      • Jun 2010
      • 239
      Thanks for the quick response. Will try those hint on my next call.
      • onlyinnewfoundland
        • Apr 2013
        • 235
        What you're describing is a boot-loop.
        See if you can load system software onto a USB stick using SST and then boot with 2+8. I had this happen once and I formatted the drive and reloaded the system software. The drive error'd out a few months later, so this may be a sign of what's to come.
        If you can get into download mode okay then it's probably not a board issue.
          Yes if the fax connector between fax and main controller isnt quite right it will cause reboots.
          • rayjeek
            • Jun 2010
            • 239
            Will check the fax before replacing any part. Thanks
            • bipc
              • Sep 2009
              • 194
              have got a couple of those before and IRC2880i with that problem, on some re-seating the main fixed it and one had to replace main2, one was the fax board damaged and got one with one of the Dimms damaged, they're a pain to figure out, when the main was damaged i couldn't get to service mode or download mode, on all others i could
              Life is a learning continuum...
              • rayjeek
                • Jun 2010
                • 239
                Problem solved. Unplugged fax kit and boots ok. Power off. and plugged fax back all running ok now. Thank you Teckat n all who contributed.
                • teckat
                  • 16083
