Hi does anyone do wide format machines as i have a Error 2813 on a W8400 can anyone advise please.
Canon Wide Format W8400 Error
Re: Canon Wide Format W8400 Error
Service Mode
Turn on printer while holding down the PAPER SOURCE(Feeder Selection) & INFORMATION buttons.
error-2813= Left print-head error
Open top cover and replace the left print-head
if----------
Intermittent error 2813 while printingY/N
Try Replacing the "Head Management Sensor" (part number: QM2-2530-000 ) AND performing "Nozzle check Position"
Check if the the belt tension idle roller guide(QE1 2691 000) is broken/ will cause the carriage not in the correct position over the head management sensor causing the intermittent issue.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Paul@justmanuals.comComment
