U have no power to printer/ so u removed DCPCB & MAIN PCB > then put them back
is the control panel green LED on
did u check your Power Supply connectors ?
check if DIMM is present on DCPCB ???
tank you
the control panel green LED is not on
Power Supply connector is check ok
DIMM is present on DCPCB I cannot understand
tank you
1-no power to printer
2-no green led
3- did u check Printer circuit breaker switch to see if tripped next to power cord CB.JPG
