Imagepress can't clear jam E1-E2 without power cycle
  • markdmt
    • 76
    Has anyone seen this, I have been working on these C7000VP's for a couple years .
    Imagepress can't clear jam E1-E2 without power cycle I think I have a faulty sensor or connection? thanks
  • teckat
    • 16092
    Re: Imagepress can't clear jam E1-E2 without power cycle
    what are exact codes in locations
    • markdmt
      • 76
      jam 010F 01
      jam 1103 02
      jam 1107 09
      jam 1105 01
      • teckat
        • 16092
        jam 010F 01
        jam 1103 02
        jam 1107 09
        jam 1105 01
        STACKER ISSUE
        did u check door switches
        FIRMWARE ver. ???????????????
        • markdmt
          • 76
          Originally posted by teckat
          STACKER ISSUE
          This C7000 has an AB1 finisher
          dc-con 56.04
          sorter 15.01
          mn-cont 87.01
          MAin board version 8
          controller version 8701.7902.5604
          bootrom 79.02-c
          I can put a paper on one of the sensors and it declairs a jam but when i remove it and close the doors it will not clear. in fact usually when you clear a jam the indicator on the screen will clear and then you close the doors to warm up.
          I also put interlock keys in the doors just in case they may not of been actuating all the way but they seem fine.
          this might have something to do with it. just threw this code
          E006 Door unit error
          0002 Illegal unit error
          Detected abnormal connection detect error when all doors are closed, from the unit listed below.
          - Registration unit
          Disconnect and then connect the connector for Registration unit
          • markdmt
            • 76
            left door interlock switch stuck in and would not actuate, repaired :-)
            • teckat
              • 16092
