ir7095 finisher-V1 jam
  • jiongpao
    • May 2009
    • 413
    Hi. Today i disable tray B function for the 2nd unit of ir7095's finisher. It always jam at the top of finisher once we use collate. Jam code 1107. After i change the buffer motor the problem solve for 1-2 hours. After that it jam at the same place.
    It seems like the delivery roller drive by buffer motor delay for transfering the paper to swing guide.
    Do i really need to order Finisher controller PCB? Or any professional advice? thank you
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: ir7095 finisher-V1 jam
    The swing guide dampers are sticking. Replace them if you can or eliminate them for, at least, a diagnosis purpose.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • jiongpao
      • May 2009
      • 413
      Sorry. May i know what are swing guide dampers and where they located?
      • spectraindo
        • May 2008
        • 313
        The paper deflectors under the upper cover has sticky sponge dampers to minimize clicking sound.
        Replace them or just tear them off (the finisher get noisy).
        • Rachid.Akli
          • Oct 2011
          • 595
          Hello,
          The paper deflector is shown with the blue arrow and the sponge damper position is approximatively shown in red arrow.
          Rachid.
          • jiongpao
            • May 2009
            • 413
            Thanks guys its really work. Just after it jamed then i removed the sticky sponge dampers for paper deflector and it run without problem until now.
