SST not allowing me to pick interface
  • kwelch
    • May 2011
    • 6
    [Misc] SST not allowing me to pick interface
    I am trying to upgrade firmware on an ir2200. I have never upgraded firmware on a Canon before. I have the latest SST and have connected my Win 2000 machine via parrallel to the ir2200. I have followed the instructions for the SST and have gotten to the point where it says to pick the interface to Download the firmware. There is nothing in the drop down list. What am I missing?
  • teckat
    • 16083
    Re: SST not allowing me to pick interface
    --------------u in Download Mode
    what ver of SST u using ?
    are u using a Nethawk USB to Parallel cable
    Why don't u use a CROSSOVER CABLE
    When Using a Bi-Centronics Interface and a Network
    The Service Support Tool allows you to select one of two interfaces to suit specific needs.
    If both are in use, you must turn the machine off and then on first before making a switch-over (i.e., from Bi-Centronics to Network or vice versa), thereby preventing errors in the event of simultaneous writing operations.
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      well you have the latests version of sst ..but you should be use the frimware ....trying search ..
      BEST TECHNICIAN . NICE PEOPLE .
      • kwelch
        • May 2011
        • 6
        The SST version is 4.72Ek and the firmware is USenv45.01. I tried just a plain old parrallel cable and also tried a crossover ethernet cable. At one point they were both connected at the same time.
        • teckat
          • 16083
          WHAT DOWNLOAD MODE ARE U IN
          use a CROSSOVER cable only (:KEEP IT SIMPLE )
          Assist Mode:
          1-Place the machine into 2 & 8 safe mode and press the START ASSIST mode button.
          2-The Service Support Tool detects what version of system software is on the imageRUNNER device and then
          provides a list of system software available for downloading on the left side of the screen.
          3-Once the software under System version is selected, it downloads entire version (unless certain Language/RUI files are turned Management Mode>Assist Mode LANG/o RUI) to the HDD.
          4-When downloading the firmware is completed, the machine will reboot and install the selected System Software
          version.
          • kwelch
            • May 2011
            • 6
            I don't know if this matters but the NIC card was recently installed for the first time and this is why I am trying to upgrade the firmware. I recently changed the machine from copier mode to Network mode and was unable to print to it. I was told I needed to up grade the firmware to finish the conversion to a network machine. Is the Crossover cable still what I need to use in light of this info?
            • HP:guy
              • Feb 2013
              • 279
              Did you replace the boot rom? It needs to be a N version.
              • irtek
                • Jun 2009
                • 109
                IR2200 can only be flashed via Bi-Centronics. That means the computer connecting has to be either Bi-Centronics or Nethawk USB cable. If using Bi-Centronics make sure the computer LPT port is set to ECP mode.
                • teckat
                  • 16083
                  (for iR2200/iR2800/iR3300)Connection cableBi-Centronics interface, obtain a parallel cableUsing a Network Cable
                  Connect the machine with the PC using a cross Ethernet cable or a straight Ethernet
                  cable
                  Points to Note When Using a Bi-Centronics Interface and a Network
                  The Service Support Tool allows you to select one of two interfaces to suit specific needs. If both are in use, you must turn the machine off and then on first before making a switch-over (i.e., from Bi-Centronics to Network or vice versa), thereby preventing errors in the event of simultaneous writing operations.
                  u can use a CROSSOVER CABLE---------
                  iR2200
                  iR2800
                  iR3300(i)
                  iR2220N(i)
                  iR3320N(i)
                  CROSSOVER CABLE
                  NORMAL POWER ON MODE
                  [Customers IP: 192.19.1.20 - Laptop: 192.19.1.21]
                  Connect in reference to customers IP Address
                  "CANNOT" PERFORM HD-FORMAT
                  CROSSOVER CABLE
                  FIXED IP MODE
                  [Set Laptop for 172.16.1.101]
                  CROSSOVER CABLE
                  SAFE MODE
                  [HOLD DOWN 2 & 8, POWER "ON" Machine]
                  PERFORMING HD-FORMAT
                  USB TO PARALLEL [FY9-4154-000]
                  [Nethawk Driver Needed]
                  SERVICE MODE
                  [SERVICE MODE>COPIER>FUNCTION>SYSTEM]
                  SERVICE MODE
                  [* 2 & 8 *]
                  PARALLEL TO PARALLEL
                  [Low Speed with Win XP/ Win 2000]
                  SERVICE MODE
                  YES for >>>>
                  iR2200
                  iR2800
                  iR3300
                  iR3300i
                  SERVICE MODE
                  [* 2 & 8 *]
                  see pdf-----------
                  iR-SST-Flash Connectivity Chart.pdf
                  • irtek
                    • Jun 2009
                    • 109
                    Sorry for the wrong information. I did not know you could flash with network cable. It would have to be N or I version or have network kit installed. The base machine did not come with a network card.
                    • irtek
                      • Jun 2009
                      • 109
                      The system must start up normally and the network settings must be correct
                      Probably the reason I did not think you could flash via network cable. Most times I was flashing the machine was becuse of HDD failure.
                      • kwelch
                        • May 2011
                        • 6
                        Yes, I took it from an ir3300.
