Problem with Canon IRC3200
  • madhusel
    • Dec 2011
    • 12
    [Misc] Problem with Canon IRC3200
    I am facing problem with canon irc3200, the machine shows that to replace all the toner catridge Black, Yellow, Cyan and Megenta.....but the toner is full only, please guide me how to solve this issues.....
  • HP:guy
    • Feb 2013
    • 279
    Re: Problem with Canon IRC3200
    What were you doing when this happened?
    • teckat
      • 16083
      it shows REPLACE or Prepare New Toner Cartridges
      or at the bottom left of the display is the message 'Install Toner Cartridge', toggling between all four colors.
      This can indicate a problem with FU27 on the fuse pcb. or other Fuses
      The indication to replace all four toner cartridges can be a result of low voltage output from this fuse (ie: 5vdc on one side and 2vdc on the other indicates a bad fuse). To check the fuse use frame ground for your volt meter negative lead and measure both sides of the fuse for 5vdc, if it measures anything other than 5vdc replace the fuse pcb. You can also check the output of this fuse at connector J64 pin 5, this 5vdc is supplied to the dc controller.
      NOTE: During normal servicing of the machine it is important to turn the main power switch off prior to unplugging connectors, failure to do so can result in damaging circuits and degrading or blowing fuses on the fuse pcb.
      I would just swap or Replace that FUSE PCB / very inexpensive pcb.
      these FUSES are hard to check > because u need to have the power up + u need needle nose meter conectors
      u can also try > remove memory-clean ends & re-seat them
      • madhusel
        • Dec 2011
        • 12
        Thanks for your reply sir, it is showing replace the toner catridges. please guide me which one i the fuse pcb please upload any pictures for identification. thanks in advance
        • teckat
          • 16083
          DC-Fuse PCB is located in the rear lower left of the machine mounted on the DC-power supply.
          Fuse PCB (FG3-3020-000)
          iR3200 DC FUSE checks_Product.pdf
          3.3 Volts DC have pink wires
          FU11 3.3vdc
          FU11 3.3vdc
          FU13 3.3vdc
          FU13 3.3vdc
          FU14 3.3vdc
          FU14 3.3vdc
          FU15 3.3vdc
          FU22 3.3vdc
          FU22 3.3vdc
          5 Volts DC have brown wires
          FU16 5vdc
          FU17 5vdc
          FU17 5vdc
          FU17 5vdc
          FU23 5vdc
          FU27 5vdc
          12 Volts DC have orange wires
          FU12 12vdc
          FU18 12vdc
          FU31 12vdc
          14 volts DC
          FU32 14vdc
          24 Volts DC have red wires
          FU20 24vdc
          FU21 24vdc
          FU21 24vdc
          FU24 24vdc
          FU24 24vdc
          FU25 24vdc
          FU25 24vdc
          FU26 24vdc
          FU28 24vdc
          FU29 24vdc
          • madhusel
            • Dec 2011
            • 12
            Thanks for your valuable information, i have replaced the fuse pcb with the another now the problem is solved, but i am facing another issue the error e220-000 is coming, please tell me how to solve this issue.
            Note: After replacing the fuse pcb, i have changed the micro switches in the front display unit, there is any chance for causing this error if i made mistake on the display unit
            thanks in advance
            [ATTACH=CONFIG]20842[/ATTACH]
            [ATTACH]20841[/ATTACH]
            FU11 3.3vdc
            FU11 3.3vdc
            FU13 3.3vdc
            FU13 3.3vdc
            FU14 3.3vdc
            FU14 3.3vdc
            FU15 3.3vdc
            FU22 3.3vdc
            FU22 3.3vdc
            FU16 5vdc
            FU17 5vdc
            FU17 5vdc
            FU17 5vdc
            FU23 5vdc
            FU27 5vdc
            FU12 12vdc
            FU18 12vdc
            FU31 12vdc
            14 volts DC
            FU32 14vdc
            FU20 24vdc
            FU21 24vdc
            FU21 24vdc
            FU24 24vdc
            FU24 24vdc
            FU25 24vdc
            FU25 24vdc
            FU26 24vdc
            FU28 24vdc
            FU29 24vdc
            • teckat
              • 16083
              imageRunner C3200 / E220 0000
              is the Scan Lamp coming on during warm-up
              Does the Error Code appears after the Scan Lamp has come on and illuminates to read the Standard White Plate. .
              First try re-seating all the connections on the Inverter PCB, Interface PCB, Reader Controller PCB, and the CCD Unit.
              check for a loss of a 24volts at J206, pins 1, 3 and 4 on the Reader Controller.
