no power ir9070
  • rdc
    • 53
    [Electrical] no power ir9070
    was in the middle of printing large job printer went out no power??? have checked for power and verified power all the way to all day circuit board goes in how do i check now? stumped ..thanks for any help...won;t power up at all..
  • teckat
    • 16083
    Re: no power ir9070
    Try powering up the copier with the Fixing / Feeding Assembly out - see if panel comes on
    No Power But >is The Green Light On Control Panel is Lit y/n
    No Power
    and No Green Light on the Control Panel y/n
    is there AC output from the All Day Power supply at J782/ J782 from the All Day Power Supply supplies AC voltage to the DC Power Supply.
    Is there 5 Volts present from J784 Pin1 on the All Day Power Supply, to the DC Power Supply
    • rdc
      • 53
      Re: no power ir9070
      .... no there is no green light on,,on control panel.....there is no voltage at pin 1 at j 784????next ///thanks for help!!!
      • teckat
        • 16083
        Re: no power ir9070
        did u check the FUSE on All Day Power Supply
        did u check this ??? u need AC in>AC out >+ DC out
        did u try to power up with fix unit out ?
