IR4570
  • akm
    • Sep 2012
    • 155
    [Error Code] IR4570
    Dear CopyTechTeam,
    Please i face a problem with IR4570 that appear the error code E- 064-001 i change the high voltage power supply assy'
    and still the error appears
    thanks
    akm
  • Luther
    • May 2006
    • 682
    Re: IR4570
    Check the drum contacts or replace the drum unit
    • akm
      • Sep 2012
      • 155
      Re: IR4570
      i want to tell you that i change the drum unit and high voltage power supply but still the error appears
      akm
      • teckat
        • 16083
        Re: IR4570
        akm
        EEPROM
        Memory DIMM on the Main controller
