iR3530 Jam~~~
  • Tze Chian
    • Feb 2013
    • 36
    [Jamming] iR3530 Jam~~~
    Hi, I got an iR3530 at first it will jam when i using paper size A4 but A4R run smooth without jam.
    But now both also jam serious, i have service the pick-up unit, roller....HELP~~
  • Iommanxman
    • Aug 2009
    • 180
    Re: iR3530 Jam~~~
    I am assuming you have set the size correctly in the paper tray? (the paper size wheel).
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Re: iR3530 Jam~~~
      Pull out pick up assy from first cassete and inspect again.(check sensor and flag)
      • Mina Banoub
        • May 2011
        • 50
        Re: iR3530 Jam~~~
        [QUOTE=Tze Chian;361086]Hi, I got an iR3530 at first it will jam when i using paper size A4 but A4R run smooth without jam.
        you posted 2 images one for the jam histroy tha indicates a stationary jam at ps10 and the other one is for a jamed paper in the fixing unit, Are you making multiple copies? Are you using different drawers for the A4 and A4R sizes?
        • zoraldinho
          • Mar 2008
          • 5015
          Re: iR3530 Jam~~~
          From the pic i see a lot of dirt and worn transfer roller.Probably you don't have any modification installed?!
          • Tze Chian
            • Feb 2013
            • 36
            Hi~~ yes i have set the size correctly in paper tray too~
            • Tze Chian
              • Feb 2013
              • 36
              [QUOTE=Mina Banoub:361264]
              [ATTACH=CONFIG]20895[/ATTACH]
              Hi~ yes both image is from the same drawer and i make multiple copies / duplex~
              • Tze Chian
                • Feb 2013
                • 36
                Hi~ no modification done before just never change~ is it possible transfer roller can cause paper jam??
                • zoraldinho
                  • Mar 2008
                  • 5015
                  Re: iR3530 Jam~~~
                  Usually no.Let's start again.Post all jam codes from jam history and printer counter please and you will receive info what exactly need your printer.
                  • Tze Chian
                    • Feb 2013
                    • 36
                    ok no problem. jam history i know whr to get,but the printer counter is it the meter reading which gt service 1 & 2?
