irc 4080 fuser reset
  • pontiac
    • 420
    Installled a new fuser, but the replace massage is still displayed, I cleared the fuser count. Any suggestions? Thanks
  • teckat
    • 16083
    Re: irc 4080 fuser reset
    Copier>Display>Fixing>FX-UHP and FX-LHP in service mode.
    If the values = 0, execute this Copier>Function>Fixing> FX-UHP-S and FX-LHP-S.
    if not check frame side connector
    FM2 7125-000 Cable Drawer
    also check these connections u remove when taking out unit
    ---in pic--
    1-COPIER>FUNCTION>FIXING>FX-UHP-S
    wait for OK !!>then
    2-COPIER>FUNCTION>FIXING>FX-LHP-S
    wait for OK !!/ then exit out of service mode
    COPIER > FUNCTION > FIXING > FIX-UHP-S > OK
    COPIER > FUNCTION > FIXING > FIX-LHP-S > OK
    COPIER > COUNTER > DRBL-1 > FIX-BLT-U > CLEAR
    COPIER > COUNTER > DRBL-1 > FIX-BLT-L > CLEAR
    • pontiac
      • 420
      Thanks for reply teckat, Sure enough it was a 2pin connector thats pluged into one of those 2port junction connectors or whatever there called. I did'nt even notice that piece and pulled out the connector on the opposite side. Thanks
      • teckat
        • 16083
        Great find\\
