Ipf8300 - 03800501-2828
  • Xdesign
    • Jun 2025
    [Error Code] Ipf8300 - 03800501-2828
    Hi!
    I'm getting a error code 03800501-2828 and command to do a cleaning on head B. I've done a testprint nozzlecheck and it seems ok. Any tip what to do?
    //Regards
    Xdesign
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: Ipf8300 - 03800501-2828
    Originally posted by Xdesign
    Hi!
    //Regards
    Xdesign
    Verify the blue(cyan) inktank is seating properly. Replace the printhead. You are using oem ink cartridges I assume?
    • Xdesign
      Originally posted by blazebusiness
      Verify the inktank is seating properly. Replace the printhead. You are using oem ink cartridges I assume?
      Hi, no only original ink! Always!! Printhead is changed for about a year ago and I was hoping that it wont be time for another already ;-( and made a test print from servicemode, nozzle check, all seems to be ok. Thanks for the tip!!
      • blazebusiness
        • 1250
        Welcome....glad to help.
        • Xdesign
          Sorry to say...but same again ... could I test the printhead in any way, in service mode?? Thanks in advance!!
