Canon IR 2880 Color Copier dog-ears copies
  • essgee
    • 10
    Copier dog-ears copies slightly on the front and rear edge of the page when exiting the internal finisher. I've replaced the front and rear face-down guides, and the 4 white plastic delivery rollers that have the rubber rings around them. I can't figure out what the copies are hitting.Steve
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: Canon IR 2880 Color Copier dog-ears copies
    Does that machine have the hole punch option? I've seen dog ears caused by problems with punch home position being off.
    • vamoursly
      • Sep 2011
      • 273
      Internal Finisher Z1 only staples, groups, collates;
      Have you taken a look at the paper between fuser and finisher, any issues before being fed?
      I did have this issue once, I removed the finisher, inspected it as you have, I found that the paper path wasnt quite true, it was sagging somehow - reinserted and it did go away, thankfully, personally I dont like the Z1 type...
      V
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5019
        Try with fresh paper
