iR C3480 latest firmware?
  • ullwn
    • 10
    What is the latest firmware for the iR C3480?
    Main Board Version -
    Controller Version -
    Scanner Version -
    Finisher{a Y1] Version -
    Thank You
    Joseph
  • teckat
    • 16083
    Re: iR C3480 latest firmware?
    System Software v95.01.01 V3
    BootROM v76.01
    Language v95.01 (JEFIGS)*
    RUI v91.01 (JEFIGS)*
    MEAP v93.01
    Pre Install App v3.40
    SDL
    v1.15.0(E)*
    v1.15.1(EFIG)*
    SSO
    v3.10.0(E)*
    v3.10.1(EFIG)*
    Portal Service v2.1.2
    Security Agent v3.0.1
    DCON v66.02
    RCON
    v52.01 CIS
    v2.03 CCD
    SDICT v20.04
    KEY v1.01
    Browser v75.02
    ASR v4.01 (JE)*
    Media v68.01
    WebDAV v80.01
    TSTMP v75.35
    Help v87.01
    Super G3 Fax Board-W2 v80.01
    Super G3 Multi-Line Fax Board-J3 v2.11
    TTS v5.01 (JE)*
    HD Format v00.13 *1 [Caution]see below
    Finisher-Z1 Fin_Z1 v6.01 (Controller)
    Finisher-Y1/Y2 Fin_Y v8.01 (Stacker)
    Saddle Finisher-Y2 Fin_Y v5.01 (Saddle)
    Puncher Unit-M1 Pun_LMNP v5.02 (Controller)
    *1 [Caution]
    For devices with SATA HDD (new type), HD FORMAT version "0012" and later should be used.
    For devices with PATA HDD (old type), HD FORMAT version "0012" and earlier can be used.
    Therefore, HDD can be formatted without problems with System v93.xx or earlier.
    However, if the Encryption Board is used in combination with SATA HDD, it is necessary to upgrade the System
    Software to v94.01.01 or later in order to
    work around any problems.
