error code image press c1
  • kapitenio
    [Error Code] error code image press c1
    image press error e000020-0485. anybody help me?pls
    • 16083
    Re: error code image press c1
    xx=01:Y, xx=02:M, xx=03: C, xx=04:K,
    xx85 = Patch image sampling (center) error 1
    DISPLAY>DENS>DENS-S-Y/M/C/K (patch image measurement value) - DISPLAY>DENS>D-CRNT-P (dark current measurement
    value) </= 30
    Difference between the patch measurement and the dark current measurement is 30 or less in patch detection
    Remedy
    1. After cleaning the Patch Sensor, execute FUNCTION>MISC-P>PT-LPADJ.
    Select DISPLAY>DENS>PCH-LED2, and check the value of PCH-LED2 (1).
    2. After removing the Patch Sensor Shutter, execute FUNCTION>MISC-P>PT-LPADJ.
    Select DISPLAY>DENS>PCH-LED2, and check the value of PCH-LED2 (2).
    3. If (1) is more than 240 and (2) is between 80 and 240, replace the shutter and solenoid. Then,
    execute PT-LPADJ again. If the value is between 80 and 240, complete the remedy. If not, go to step 4.
    4. After replacing the Patch Sensor, execute PT-LPADJ. If the value is between 80 and 240, complete the
    remedy.
    There are several things that can cause E020COPIER>DISPLAY>DENS>SGNL-Y/C/M/K with the Initialization setting in COPIER>ADJUST>DENS>SGNL-Y/C/M/K.
    COPIER>DISPLAY>DENS>SGNL-Y/C/M/K arethe ATR Sensor readings of the Developer in its present condition and should be within +/- 50 of the Initialization settings.
    COPIER>ADJUST>DENS>SGNL-Y/C/M/K arethe Initialization settings that the copier maintains and are located on the door sheet.
    2. If the Initialization setting is not the same as the door sheet, be sure to enter the correct value and replace the Developer Unit.
    3. If the ATR Sensor reading is over +/-50 of the Initialization setting; the ATR Sensor, Patch Detection Sensors, Drum Unit and DC Controller are suspect.
    Check the status of the Drum Unit under COPIER>COUNTER>DRBL-1>PT-DRM. The Patch Detection Sensors looks at patches of toner that are generated on the drum for each color and determines the amount of toner that is in each patch by the amount of reflected light. If the drum is not creating these patches correctly, the patch readings will be affected. Replace the Drum Unit if it is close to or over 100% of its rated life.
    If the Drum Unit is not close to or over its rated life, replace the ATR Sensor and Patch Detection Sensors. If the error continues replace the DC Controller.
    5. If over toning continues to occur the Developing Clutch (CL1) may be sticking and need to be replaced.
    • DANIELCANON
      • Jun 2011
      • 187
      Hola teckat, a mi tambien me esta pasando lo mismo con una maquina y quisiera profundizar en el tema.
      he realizado lo siguiente:
      cambio de kit cables (FM2-2615.000).
      cambio de unidad de sensor de cuadros completa (FM2-2494-000).
      Ademas he retirado del sensor de cuadros el obturador de dicho sensor (FL2-2710-000).
      He realizado:
      FUCTION/ DPC / DRM RST varias veces.
      FUCTION /MISP-P / PT-LPADJ.
      PCH LED 1 = 240
      PCH LED 2 = 197
      PCH LED 3 = 195
      El valor de PCH LED 1 no bajaba.....
      luego de borrar la dc cont y la MN CONT los valores de los 3 sensores de cuadros son correctos
      PCH LED 1 = 194
      PCH LED 2 = 197
      PCH LED 3 = 195
      pero aun con estos valores el codigo sigue apareciendo cuando se envia una cierta cantidad de hojas ( entre 20 a 30 pruebas).
      • HELIO240
        • Jan 2011
        • 137
        Hi , are you check the Hardness of the drum .Change it.
        • Ricardo25
          • Feb 2013
          • 9
          Hola,
          Quizás te falte colocar en ADJUST- DENS y P-PASCAL los valores que están en la puerta frontal sin eso valores la maquina no puede leer bien el parche del sensor de cuadro.
          EJEMPLO:
          {DENS}
          DGNL-Y 497
          DGNL-C 430
          DGNL-M 400
          DGNL-B 453..
            • 16083
            did u see that post was from JUNE 2013
            • mrban
              • Sep 2012
              • 25
              P-sens-p =0, p-sens-s = 0 check sensor ps7 (check cable).
