Canon fax-JX200 problem line in use.
  • tibbs
    • Aug 2008
    • 225
    Hello I have a couple of canon fax machines with this problem. LINE IN USE. Does anyone have this problem ?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5011
    Re: Canon fax-JX200 problem line in use.
    Press the off/on button for 3 cec. to turn off fax machine and turn on again with one single press on the same button.
    • Cabo
      • Aug 2012
      • 41
      I have this problem.You must enter a new software but you have to have an adapter for it.Now I do not know the parts number for adapter I have to work tomorrow so I send you.
      Sorry for my English
      Regrds from Montenegro
      • teckat
        • 16083
        Do u have an Answering machine connected to Fax
        if so>
        Set the Answering machine to answer on the first or second ring
        When recording an outgoing message on the Answering machine, the entire message must be no longer than 15 sec.
        • Cabo
          • Aug 2012
          • 41
          Parts number: Cable HY7-3434-000
