iR2018 Error Code E247
  • Blues Guy
    • Aug 2009
    • 216
    [Error Code] iR2018 Error Code E247
    Hi guys,
    Have these problem with these machine iR2018 error code E247. I know the error code is related to serial number and counter p.c.b. I have make sure to fix back the original serial number and counter p.c.b to these machine but still appear the error code.
    Is there anyway to reset back memory of the main controller p.c.b to accept back the original serial number and counter p.c.b ?
  • teckat
    • 16083
    Re: iR2018 Error Code E247
    Originally posted by Blues Guy
    Hi guys,
    U CAN TRY TO DO A E355 CLEAR / see pdf
    E247--
    An error has been detected in the result of verifying the soft counter reading stored on the Counter Memory PCB and
    SRAM.
    Counter Memory PCB is a matched board with the Serial Number PCB and cannot be swapped with one from any other equipment. Doing so may change the error code and will not correct the problem
    Replace Counter Memory PCB with new one. FM2-2799-000
    iR B&W Counters_TP05 108d.pdf
    • Blues Guy
      • Aug 2009
      • 216
      Yeahh....change a new counter P.C.B problem solved. Save $$$ don't have to change the main controller P.C.B.
      What a challenging week one problem after a another come. Any way thanks you guys for the information.
      • teckat
        • 16083
        keep a copy of that board pdf with printer & in shop
        http://www.copytechnet.com/forums/at..._tp05-108d.pdf
        learn not to make same mistake twice on swapping pcb's
