canon ir3030 cant receive fax but can send
  • vandezo
    I don't know
    • 161
    [Misc] canon ir3030 cant receive fax but can send
    Does any one know ?
    canon ir3030 cant receive fax but can send .
    I tried to on-hook with another line and another machine, apparently the phone does not want to run to the fax tones as usual
  • Luther
    • May 2006
    • 682
    Re: canon ir3030 cant receive fax but can send
    probably using a voip phone line, change the baud rate to 9600 or 7200, Disable any bandwidth saver settings on you VoIP line. With most VoIP providers, you will have a bandwidth saver setting that helps assure voice quality during transmission of your conversation; however, this setting can result in loss of data packets and thereby hinder your ability to send faxes
      • 16083
      Originally posted by vandezo
      Does any one know ?
      Is the processing data light flashing indicating it is receiving a fax.
      Checking the job>, you may find that a print or fax job is being held in the queue.
      In service mode perform an all clear.
      SERVICE MODE> FAX > CLEAR > ALL
      Power cycle the machine.
      Note: Be sure to print out the fax user data list prior to doing the fax all clear and re-enter the data once the clear is complete.
      • HP:guy
        • Feb 2013
        • 279
        Is it on a PBX? it might need the switch reset.
        • Klydon
          • Mar 2009
          • 243
          Would also recommend turning ECM off as well. What happens if you call it on a regular phone? Will it pick up? Do you hear tones from the machine?
          • vandezo
            I don't know
            • 161
            ok. thanks all,
            i will try last week
            now i left to other city
