canon ir2318
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Error Code] canon ir2318
    hello... hello technician friends well it have ir2318 if we copied 20 copy we have this error code * E000019-0002 ...we should be making this machine off ..and started again ..please help .
    BEST TECHNICIAN . NICE PEOPLE .
  • mido
    • Nov 2011
    • 177
    Re: canon ir2318
    Hi,
    I think the waste toner bottle full.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      Re: canon ir2318
      I think that unit is like the USA IR 2020 series. Replace the NPG-28 drum unit. I don't believe that model has a waste toner bottle. The waste toner is stored in the drum. Empty it or replace it. Other things to check----waste toner full sensor. If drum is not full....clean that sensor.
      • HELIO240
        • Jan 2011
        • 137
        Re: canon ir2318
        hi, my friend this error is a waste toner error . If the waste toner bottle is full the same must be changed. Other error code that are relative bottle the toner is E0013 for example in canon ir 1023.
        • blazebusiness
          • 1257
          Re: canon ir2318
          Bottle? What bottle are you talking about? Empty or replace drum unit and be done with this problem. Or check that sensor.
          • zaza
            MECANOGRAPHE
            • Mar 2008
            • 1095
            Re: canon ir2318
            Thank you all ....l check this drum unity l see this sensor is broken cause it is not in her place ...so l replace on by another and all is good .......l solve my problems ..again thank you all technician ..and l appreciated all your reply ...thanks .
            • HELIO240
              • Jan 2011
              • 137
              Re: canon ir2318
              if you need us we are here.
              • zaza
                MECANOGRAPHE
                • Mar 2008
                • 1095
                Re: canon ir2318
                thank you very much ....if you want joint me contacted me by my skype: zahroun19 ..you are welcome there ..
