error code 0004 in canon imagepress c1
  • HELIO240
    • Jan 2011
    • 137
    [Error Code] error code 0004 in canon imagepress c1
    Hi,guys l have a canon IPRc1 that are given the error E0004 after the spring pressure the fuser be broken and fall to the heater .I changed the all the pcbs : dc controller , main controller , every pcbs font , fuser, process unit, fuser conector , door conector and the copier still are show the error .
    please somebody can help me. The error subcode is 0003 .Thanks in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5005
    Re: error code 0004 in canon imagepress c1
    Reset error?
    • teckat
      • 16083
      =================don't understand why u would replace all those parts on this error code/ if u worked for me u would be fired
      did u have a P PRINT to load back the settings for DCON ???
      before u pulled out & replaced DCPCB ?
      did u clear the ERROR CODE in service mode ??
      ALSO CHECK YOUR CONNECTIONS/ & see pdf
      E004 Sub Codes.pdf
      • HELIO240
        • Jan 2011
        • 137
        yes , I execute clear error in service mode.
        • teckat
          • 16083
          • HELIO240
            • Jan 2011
            • 137
            hello, how I told , I executed various procedures , I tested some conectors such as font ac , Lamps of the fuser , Temistors, termosw and change the some pcbs all related to the error description in the manufacturer's manual. I would like more information about this problem , the basic got made , how execute function clear error perhaps that is why I was not fired. How I told the tension spring left broke and fallen in the lamp of the heater and this caused a short after the copier do not worked more . Honestly I need the help. Now only remains for me to play the improbable. thanks in advance.
            • teckat
              • 16083
              Check circuit breaker in printe\ Check Fuses
