0101 is right deck pickup up sensor. service mode function/sens-adj run op-sens. They should all pass. If you get this jam code regardless of paper source(check table) then the paper is passing by the sensor without it being detected. Make sure that the prism on the right door and under metal plate on pickup assembly(the one you remove to replace rollers) is clean and ok. Also make sure that the transmitter and receiver in the right pickup assembly are clean and properly aimed
