Anyone knows how to calibrate Imagepass B1 on IRADV 5051. Customer place we try to calibrate it but never works or its works different way.
Imagepass B1 For ADV. 5051
Re: Imagepass B1 For ADV. 5051
http://www.copytechnet.com/forums/ca...ht=calibration
All Fiery RIPs on Canon printers are calibrated the same way.
If there is no Calibration button, you have to reload system software on the Fiery. -
How to Perform an Accurate Calibration Adjustment.pdf
proper sequence to calibrate copier and imagePASS
Sequence is to do an AUTO COLOR MISMATCH first, then a CORRECT SHADING, followed by a full AUTO GRADATION, then COLOR CALIBRATION for the imagePASS.
CORRECT SHADING and COLOR CALIBRATION should be performed using a Spectrophotometer (i1 Basic Pro). (Expensive)
Fiery Calibration:
When to calibrate is a commonly asked question. When a noticeable change to color quality has occurred, before printing large jobs, after a PM and any time a job contains critical color requirements are just some of the instances that would necessitate calibration. However, depending on the print environment, a user may also choose to calibrate each time a job calls for different paper stock!
Calibration compares the current performance of the print engine with its optimum performance. To maintain consistent color, calibration is a must.
Note: You will need a Kodak Color Separation and Gray Scale Guide to complete this exercise.
1. EFI Color Wise software offers step-by-step instructions for calibration and supports a variety of calibration instruments.
a. Start by launching Color Wise from Command WorkStation or from the Windows Start menu by selecting Start > All Programs > Fiery > Color Wise Pro Tools
2. Select the output profile for the Printer - Print controller that you are working with, and then click Select.
a. If your equipment is not listed, click Add to initiate a search for all networked Fiery servers.
3. Enter the password for the Fiery. The default password is Fiery.1. Now click Login.
4. When the Color Wise Pro Tools application launches, click Calibrator
Note: Note: You may either print a Comparison Page or a Sample Image Page from the Hold Queue in Command WorkStation. Select to print the Comparison Page Evaluating The Results Of The Comparison Page.
The top two rows show the path taken by RGB data through the Fiery. The first row of thumbnails displays the default calibration. The second row displays the images with the proposed calibration. The bottom two rows show the path taken
by CMYK data through the Fiery. Row three displays the default calibration with no simulation. Row four displays the thumbnails with the proposed calibration and a CMYK simulation.
19. In addition to evaluating the Comparison Page, you may also view the results of your calibration in Step 6 - View Measurements. Select Measurements vs. Target from the drop down menu and then click View.
20. The graph displays the tone curves of measured density values plotted against optimal or target density values for each color channel
a. Click the icon next to each color channel on the right hand side of the Measurement vs. Target window to view one color at a time
b. The thicker line in the graphical display represents the Target density values, while the thinner line represents the measured density values.
c. The right hand side of the Measurement vs. Target window also lists the maximum density values (D-Max) for each color.
d. In general, we would like to see measured D-Max values meet or exceed the target D-Max values for each channel. A measured D-Max value falling below 10% of the target value is a strong indication that calibration will not compensate
for color discrepancies and that service is required.
21. Place a check mark next to Apply to all calibration sets so that your calibration is applied to all supported output profiles. This ensures that the appropriate calibration is applied when mixed media is used in a print job!
22. Now click the Customize button
23. You may select the stock for which calibration should be applied. When complete, click OK
24. Now click Apply to accept the calibration. Now click Save To File
25. You may save your calibration as either a measurement, a simulation or as a new target for use as a benchmark for future calibrations. Click the Measurement radio button and then click OK
26. You may save your calibration anywhere on the network. The default location is in the Color Wise Pro Tools folder. For this exercise, click Cancel
27. When you return to the Calibrator window, click done. You have successfully calibrated your device.
efi Fiery Calibration.pdf**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
when i kept measurement page on the glass and try to scan somehow its picking up from the feeder, not from the glass. and giving jam error.
Need to upgrade driver i guess, but i think its updated.
will check again. any more
u can skip the Scanner Calibrationnot needed
just follow the pdf instructions for ADVANCED series > Printer first >then the Fiery(imagePass)**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
I have this same problem on a c5045 w/B1 that I just got in and am getting ready to deliver to a customer next week. Does anyone have a link to the patch or can maybe pm me with info on where I can get it. I'm not an "authorized" Canon tech so I can't download from the Canon support site. Thanks.Comment
imageRUNNER ADVANCE C5030 / C5035 / C5045 / C5051
Fiery Patch 1-19Q9Q0 for the imagePASS-B1 v1.01. This patch resolves an issue where a jam is reported at the Automatic Document Feeder when a ColorCal calibration is performed on an imageRUNNER ADVANCE device with v55.xx (v2) firmware or above.
Release of Fiery Patch 1-19Q9Q0.pdf
see attachAttached Files**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Hi, I have the same problem with a imagePASS A1, please any solutionComment
Fiery Patch 1-19Q9PI for the imagePASS-A1 v1.0.
This patch resolves an issue where a jam is reported at the Automatic Document Feeder when a ColorCal calibration is performed on an imageRUNNER ADVANCE device with v55.xx(v2) firmware or above.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
