E 0008-0001 IRC 5180
  • DANIELCANON
    • Jun 2011
    • 187
    Hi, everybody as I can fix the code without changing the fixing unit.
    is this possible?
    thank you...
  • canonbundy
    • Jun 2012
    • 607
    Re: E 0008-0001 IRC 5180
    is this possible?
    thank you...
    Hi Daniel.canon, lots of Posts on these Units, the Error refers to a load on the Fixing Unit Drive - check for wear on motor drive gears, crank the unit by hand and feel & hear tightness/noise from steel Belt drive gears, check P-PRINT for life of Upper Belt if under 40% maybe contact Canon for warranty as they know from Dealer pressure the problems faced.
    • its_just_a_copier
      • May 2011
      • 132
      is this possible?
      thank you...
      First check service modes COPIER/COUNTER/DRBL-1/FX-BLT-U is cleared. Also in Service Level 2 COPIER/OPTION/BODY/FXMSG-SW is set to 0. If both of these are correct, print out P-Print COPIER/FUNCTION/MISC-P/P-PRINT and perform DCON clear COPIER/FUNCTION/CLEAR/DCON. You will have to re-enter most values in COPIER/ADJUST, but this will FIX your E008. Arriba Alianza!
      • teckat
        • 16083
        what u do is remove the Fix Unit to inspect /
        then throw it in the garbage >
        go online and order a refurbish one
        • DANIELCANON
          • Jun 2011
          • 187
          Ok muchas gracias a todos por sus comentarios, sera necesario cambiar la unidad completa.
          • teckat
            • 16083
            ahh... y ARRIBA ALIANZA TODA LA VIDA.[ATTACH=CONFIG]21224[/ATTACH]
            • Simons
              • Jun 2008
              • 490
              I got this on a canon refurb that was 2 months old. Junk. The fuser has over 20 bearing in them and canon does not replace them all when they rebuild them .
              • teckat
                • 16083
                Live & Learn
