Canon CLC 5100 bypass noise
  • yanpwang
    • Jun 2025
    My friend have a Canon CLC 5100, make noise when feeding from bypass tray. Any suggetion?
    Thank you
    Yan
  • Luther
    • May 2006
    • 682
    Re: Canon CLC 5100 bypass noise
    replace all the feed rollers
    • teckat
      • 16083
      to add on>
      remove all the pick-up units > to inspect> replace all paper feed rollers>
      that reg unit needs to be blown out with can air/
      after u blow out (all that paper dust) > then u clean off the long reg rollers damp rag w/water (alcohol dries out rubber)
      also replace those cassette pick-up/feed/ & sep rollers
      see pdf for help--
      Rollers Part Replacement CLC5100-4000 .pdf
      posted pdf is for review if needed-
      I would recommend to have a Canon trained tech service that model>
      • yanpwang
        Thank very much!
        • yanpwang
          Do you have part # for those rollers? And any suggest web site to buy it.
          Thank you!
          • teckat
            • 16083
            Thank you!
            MULTI FEED ASSEMBLY
            FF5-4327-000 /2 /ROLLER, PICK-UP
            FF2-4710-000 /1 /ROLLER, MULTI SEPARATION
            FF5-4331-000 /1 /ROLLER, FEED
            CASSETTE PAPER PICK-UP ASSEMBLY
            (this is for two cassette units> if u have four> just double)
            FB5-6586-000 /2 /ROLLER, SPONGE
            FF9-1913-000 /2 /ROLLER, PAPER FEED
            FF5-7829-000 /2 /ROLLER, PAPER PICK-UP, 1-front
            FF5-7830-000 /2 /ROLLER, PAPER PICK-UP, 2-rear
            Deck-R1
            FB2-7777-020 /1 /ROLLER, SEPARATION
            FF6-1975-000 /1 /ROLLER, PAPER FEED
            FF5-7829-000 /1 /ROLLER, PAPER PICK-UP, 1-front
            FF5-7830-000 /1 /ROLLER, PAPER PICK-UP, 2-rear
            • yanpwang
              Thank you!
