E000020-0485 Canon Imagepress C1
  • Hayk
    • 14
    [Error Code] E000020-0485 Canon Imagepress C1
    After printing few pages appears this error. How can I solve this problem? Thank you
  • its_just_a_copier
    • May 2011
    • 132
    Re: E000020-0485 Canon Imagepress C1
    Check your Service Mode values for COPIER>DISPLAY>DENS>PCH-LED 1,2,3
    They should all be a similar value, if one is 240 the Drum Patch Sensor shutter is not being opened all the way, check the solenoid / armature at the rear side of the Processing Unit for defects. Since this requires removing a heavy chunk of the machine, usually techs like to just remove the Drum Patch Sensor shutter and see if the code goes away to prove it first. However this is for troubleshooting only, you cannot leave this shutter off because the sensor will get dirty very quickly.
    If the code doesn't change, try replacing D kit harness (part number FM2-261 5-000) . Very common for this harness to go bad as you have to pull on it to remove the drum...
    • Hayk
      • 14
      thanks for answer.
      PCH-LED1 155
      PCH-LED2 240
      PCH-LED3 151
      I must slide out processing unit and clean sensor?
      • its_just_a_copier
        • May 2011
        • 132
        thanks for answer.
        PCH-LED1 155
        PCH-LED2 240
        PCH-LED3 151
        Well yes, just slide the Drum unit out and clean that sensor (and make sure the metal shutter covering the sensor is working properly.) Most likely the PCH-LED2 is referring to the CENTER sensor of the three, which may indicate it's just dirty. Good Luck!
        • Hayk
          • 14
          Can't slide out processing unit. I have done everything what is shown in service manual
          • Hayk
            • 14
            I solved the problem I just pulled out drum unit, cleaned sensors and now everything is fine. PCH-LED2 is now 143. Thank you very much.
            • its_just_a_copier
              • May 2011
              • 132
              Excellent.
