hello guys, I would like your help in Canon imagePRESS C1. My problem is the following the copier to run the test pg 10, only prints the yellow other colors do not appear. I already changed the drum kit, and drive assembly hvt5 drum was damaged. Now time it prints using the yellow PG10, time she goes all blank. What do u think it can be. thank you in advance.
C1 print all blank
Re: C1 print all blank
make sure your TEST PRINTS settings are correct--in service mode- COPIER>TEST>PG
TYPE = Input a type number for test print. Press the Start key and perform test print.
*****(Be sure to return to 0 after completing test print.)
Setting value
0: Image from CCD (normal print)
1 to 3: For development
4: 16 gradation
5: Halftone for the whole image
6: Grid
7 to 9: For development
10: MCYBk Horizontal stripes
11: For development
12: YMCBk 64 gradation
13: For development
14: Full color 16 gradation
15 to 200: For development
[Factory setting value / Value after RAM clear: 0]
Make sure all colors are set to "1"
COLOR-Y/M/C/K= Set whether or not to display each color at each type.
For example, to output a single M color, set COLOR-M to 1 and set other items to 0.
Setting value 1
0: Do not display the color.
1: Display the color.
[Factory setting value / Value after RAM clear: 1]**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Setting value
4: 16 gradation
6: Grid
11: For development
13: For development
Setting value 1
[Factory setting value / Value after RAM clear: 1]Comment
how are glass copies ?
error code ?
post your PG10**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
