Canon imageRUNNER ADVANCE C9065 problem
  • dungtn
    • Oct 2012
    • 24
    Hi!
    I've problem with Canon imageRUNNER ADVANCE C9065
    Pls help me!
    Thanks.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: Canon imageRUNNER ADVANCE C9065 problem
    Originally posted by dungtn
    Hi!
    [ATTACH=CONFIG]21206[/ATTACH][ATTACH=CONFIG]21207[/ATTACH]
    Pls help me!
    Thanks.
    Copy quality issues are extremely common on this series.Stop the copy on the ITB and see if it looks ok. If not ----when was the last time drums & dv units were replaced? If image looks ok on the ITB then perhaps the fuser belt has issues. How many clicks on that box? If the drums are nearing end of life.....might be a good thing to start with. These boxes need to have the image adjustments done almost daily to maintain good quality....I'm assuming you've already done that. The older IR Color boxes were much more forgiving if you did not run image adjustments often...the Advance series is not.
    • dungtn
      • Oct 2012
      • 24
      Thanks for your help!
      Counter is 150k.
      Do have I had to replace drum?
      • vigour
        • Aug 2010
        • 1038
        If you are asking about the lines,
        Run a PG5 of each separate colour, to tell which one has a problem.
        As the man said, your drums most likely need changing.
        Check service mode > Counter > LF to see the drum life.
        YMC drums near 100% is no good, if you are running heavy coverage graphics
