E009-0001 Error - Canon IR C3080
  • prntrfxr
    • 1622
    Copied 200 pages. Let machine sit a while and this error came up. Any ideas?
    • 16083
    Re: E009-0001 Error - Canon IR C3080
    E009-0001 =can be displayed when the output of the fixing pressure release home position sensor does not change although the fixing motor is rotated and reversed.
    "E009-0001" , I would first inspect or replace the fixing pressure release home position sensor (PS13)
    1. Re-fit the connector of the fixing pressure releasing home position sensor.
    2. Re-fit J2006 and J225 connectors of the DC controller PCB.
    3. If the symptom still occurs, replace the fixing pressure releasing home position sensor (PS13) with a new one.
    4. If the symptom still occurs, replace the fixing motor (M3) with a new one.
    5. If Step4 does not work on the symptom, re-fit all the connectors of the DC Driver PCB.
    6. If Step5 does not work on the symptom, replace the DC Driver PCB with a new one.
