IR 1133IF Colour Scanning - Banding Problem
  • fiftyatfour
    Hi Guys,
    This one is driving me mad... any help would be much appreciated.
    The 1133 is producing "Bands" when scanning in colour, both from the plate and through the feeder.
    B&W scanning is fine, normal printing and copying is fine (in B&W as its a B&W printer).
    Its not a driver issue as the bands also appear when scanning locally to a memory stick.
    Its running the latest firmware.
    I have had the glass off to clean under the calibration strip but still no change.
    I think it could well be a setting that has been reset/cleared by accident in the service menu so im hoping its something simple.
    Please help...
    Images attached.
    Thanks.
    • 16083
    Re: IR 1133IF Colour Scanning - Banding Problem
    Originally posted by fiftyatfour
    Hi Guys,
    Please help...
    Images attached.
    Thanks.
    Color Image Reader-L1 ? is this the reader installed
    if so > have u Performed a Full Auto Gradation for Color Reader ??/
    see ----
    • fiftyatfour
      Hi teckat,
      Apologies for the late reply.
      I dont know much about these, but its not an L1 on there. The unit is much cheaper.
      Ive looked all around it and cannot find the reader model on the machine or in the specs.
      Also regarding the full auto graduation instructions.... If it helps at all - In the:
      [Additional Function]>[Common Settings]>
      The only options available are:
      Draw Auto Selection
      Switch Paper Feed Method
      And in the:
      [Service Mode]>[Copier]>[Option]
      Body
      User
      Acc
      Lcns-Tr
      Lcns-Of
      I appreciate any advice you can offer.
        • 16083
        Hi teckat,
        Draw Auto Selection
        And in the:
        Body
        User
        Acc
        Lcns-Tr
        Lcns-Of
        sorry was thinking about the imagePress 1135
        I see now_______so this is your set up
        imageRUNNER 1133iF: Color Flatbed and Duplex Automatic Document Feeder (DADF)
        • fiftyatfour
          That's the one.
          • fiftyatfour
            Anybody, any ideas?
            Thank you...
              • 16083
              Anybody, any ideas?
              Thank you...
              could be an issue with the CIS --contact image sensor
              is this issue in same location on all color scans ??
              • fiftyatfour
                Yes - Same location on all scans (Colour)
                Come to think of it greyscale looks quite light as well (although no bands)
                Im fairly sure that its an accidental service menu setting change as it worked fine before it was moved to another network.
                  • 16083
                  get a trained tech on product if available
                  it's the CIS that separates the Color Scan > output between CIS channels>shading start point
                  in service mode do u have a SCAN TEST
                  • fiftyatfour
                    In Service Mode I have:
                    [Copier]
                    [Feeder]
                    [Fax]
                    [Test Mode]
                    In the Test Mode I have:
                    [Printer]
                    [Fax]
                    There doesnt appear to be a SCAN TEST in any of the above menus.
                    • fiftyatfour
                      teckat,
                      In a last gasp of desperation I just did this in Service Mode...
                      [COPIER]>[FUNCTION]>[CCD]>[CL-AGC]
                      And it has almost resolved the issue.....
                      The copy from the glass plate is much better and the scan from the feeder is showing lines, but at least I can scan from the glass plate now...
                      As you can see though, I seem to have "shortened" the scan by 2-3cm in doing this. Would you know how to set this back to full A4?
                      And I would think it is likely to be a sensor setting rather than a paper size selection?
                      Thank you.
                      Colour Through Feeder.pdfColour From Glass Plate.pdf
                        • 16083
                        teckat,
                        Thank you.
                        [ATTACH]21276[/ATTACH][ATTACH]21275[/ATTACH]
                        did u check your Service Label ??
                        U may need to put back the Label SETTINGS !!!!!!!!!!!!!!
                        automatic gain control (AGC)
                        • COPIER > FUNCTION > CCD > CL-AGC (CIS light intensity adjustment (color)).
                        • COPIER > FUNCTION > CCD > BW-AGC (CIS light intensity adjustment (B&W)).
                        do u see this setting at all >>>>>>>>>>>
                        MF5900/D1300 Series/ may be similar to your 1133iF ???
                        After replacing CIS units:
                        1) Check that there is no problem with the setting values written on the service label.
                        2) Close the ADF, and execute the following service mode. If it results in NG, execute it again after turning OFF and then ON the power.
                        3) After executing the following service mode (a), check the value automatically set with the following service mode (b), and write it in the service label.
                        (a) COPIER > FUNCTION > INSTALL > STRD-POS (executing automatic detection of the reading position at DF stream reading)
                        (b) COPIER > ADJUST > ADJ-XY > STRD-POS (adjusting the reading position at DF stream reading)
                        4) Place a blank paper on the Copyboard Glass, and execute white level adjustment in the following service mode.
                        • COPIER > FUNCTION > CCD > DF-WLVL1 (white level adjustment [copyboard scan])
                        • COPIER > FUNCTION > CCD > DF-WLVL3 (white level adjustment B&W [copyboard scan])
                        Next, place the same blank paper on the DF and execute the following service mode.
                        • COPIER > FUNCTION > CCD > DF-WLVL2 (white level adjustment [DF scan])
                        • COPIER > FUNCTION > CCD > DF-WLVL4 (white level adjustment B&W [DF scan])
                        • fiftyatfour
                          Thanks teckat,
                          That seems to have done the trick.
                          Out of interest I cannot see a service label anywhere on the machine?
                          I take it, it should just be on the back somewhere..
                          Does the service label just contain the same defaults that are in the Service Manual?
                          The machine you mentioned (D1300 Series) does indeed seem identical to the 1133IF unit I have.
                            • 16083
                            Thanks teckat,
                            believe the Label may be on metal plate that covers Main Controller in back of printer (u need to remove printer back cover to view)
                            Label has factory tested settings for your printer & it may show the standard defaults also /
                            Very Important before u clear RCON or DCON U NEED TO
                            or hopefully they are still on label in printer- they default back to the Manual defaults after a CLEAR.
                            Think in your model u can use a USB to export/import the Main Controller pcb settings before/on replacement of it-
                            get a manual
                            Tested settings are used when u replace Boards, ADF unit, Reader unit & it's settings needed, CIS unit,Document Exposure / Feed System settings and many more
                            Backing up Service Mode
                            Each device is tuned at the time of shipment and the tuned values are written on the service label.
                            However, when replacing the main controller PCBs / DC controller PCBs or clearing RAM, tuned ADJUST and OPTION values are reset to defaults.
                            Each service technician should adjust these values in field and ensure to write values after changes in the service label. If the
                            corresponding item is not found on the service label, enter the value in the blank space.
                            • fiftyatfour
                              Thats Great.
                              Many thanks for your efforts once again.
