IRC 3380i Canon E749
  • fotocom
    • Nov 2008
    • 96
    Hi ,
    I have a Canon MFP with the following error E749 its an IRC 3380i.
    The manual describes the fault as follows: E747
    E747 Main controller PCB error (Image processing ASIC or memory control/communication control ASIC)
    A reeboot sorts the prolem , but it returns a day later. Any ideas?
    Thanks in Advance....
  • teckat
    • 16083
    Re: IRC 3380i Canon E749
    Originally posted by fotocom
    Hi ,
    u quote posted two different codes ?
    if it's a 747 code > do the Board Cleaning/Adjustment >see pdf>works 95% of the time
    Board Cleaning_Board Position-TP07 094.pdf
    if it's a 749 code > u can remove Boot Rom to re-seat it/ hopefully u have the correct one in there
    • fotocom
      • Nov 2008
      • 96
      Apologies its the E 747 code.
      • fotocom
        • Nov 2008
        • 96
        Thanks teckat,
        carried out Board Cleaning/Adjustment , the area around the boards was full of dust.
        Gave the area a blow out. Checked and reseated the boards. Problem resolved.
        Thanks again, great result.
        • teckat
          • 16083
          Thanks teckat,
