in ir 2520 gear number FM3-9293-000 (MULTI PAPER PICK-UP GEAR ASS'Y) AND THE STEEL ROD PASSING THROUGH IT is not working properly it do not lift the paper from bypass and also jams the paper from stack bypass
whats the solution
there is no error code
whats the solution
