ERROR CODE E000100-0001 in Canon IR 4570 machine
  • jack
    • Jul 2025
    hi all,
    i m facing problem in IR 4570 with error code e000100-0001.
    Please help me
  • teckat
    • 16083
    Re: ERROR CODE E000100-0001 in Canon IR 4570 machine
    Originally posted by jack
    hi all,
    Please help me
    Grounding Clip (FC5-0539-000) should be contacting the Registration Roller/ check that first
    Check the H.V. Resistor contacts to make sure they are secured and not broken. Also check grounding plates on metal registration roller, only the operator side tab should be touching the roller and the non-operator side should be in contact with the upper guide plate.
    Also check the Laser Shutter Mechanism
    • canonbundy
      • Jun 2012
      • 607
      hi all,
      Please help me
      3 Pin connector from LSR Unit to rear frame of machine under Toner Drive mech fills with toner and shorts, also the same connection behind the Rear cover will give the same error - vacout, clean & reseat both.
