ir 2022 2sided copying off.
  • MWALA
    • Sep 2011
    • 30
    How do you turn on 2sided copying on ir 2022
    • 16083
    Re: ir 2022 2sided copying off.
    Duplex Unit A1 or B1 ?
    Was option displayed before ? if so check>>>>>
    Duplex
    Unit is connected by a 11 pin connector located on the left rear corner of the iR. In this case, the left side door was removed from the iR for servicing and the 11 pin connector was not properly connected. Try Re-seating the connector for the Two-Sided issue.
    also
    Check in user mode setting of Printer Settings>2-Sided Printing> make sure it is set "ON",
    Duplex OPTION is missing on Panel ??
    Only the 2 to 1 sided option is available as seen in pic
    check duplex intermediate connector on the left door.
    Re-seating the connector should corrected the problem. The following photograph shows the connector after removing a small black cover.
    • canonbundy
      • Jun 2012
      • 607
      Was the Fixing Assy removed? If the Left Door is removed without the duplex connector removed 1st it can cause THAT connector to become unplugged inside the Door.
      • canonbundy
        • Jun 2012
        • 607
        Duplex
        [ATTACH=CONFIG]21304[/ATTACH]
        also
        [ATTACH=CONFIG]21303[/ATTACH]
        Hi teckat, if the duplex connector is unplugged the display will not show (greyed out) 2 sided option.
        • mjarbar
          Silly question I know, but do you have the Duplex Unit-A1 or B1 and the Power Kit-Q1 installed on the machine? Open main left hand door and look for serial number label just inside top of door.
          If it is, as Teckat said, check the connectors are seated correctly etc. Once on select "2-sided" from the control screen and it should give you the option of 1-2, 2-2, book-2 and 2-1 sided copying.
          The question was worded a little vaguely
            • 16083
            thanks, that pic was for> if in user mode two sided setting was off/
            should have said that
            • MWALA
              • Sep 2011
              • 30
              Thanks guys for your suggested solution. Actually the 12 pin connector was half connected. After securing the connector it really solved the problem.
              But guys I felt let down, mjarbar refered my problem as silly.Himself as a tech on this forum, that was the last word i expected from a skilled person like him.In future lets respect others regardless of their technical expertise.Leaning is endless.That is why we have this forum.
              Thanks everyone once more.
              • cuongdigital
                No way to turn his position is ON for Side Two players who would like a forum only for very urgent help ? With his back was thoroughly wired Test & JP and still not face as well as photo printing & 2 you have the piece of paper into the Sensor Test wedge Duplex Ready remained normal machine showed that the PBC should have no problem Boad of Brotherhood or to reflash the firmware for it , right ?? because previously the previous storm Drum jams so I usually skeptical but clearing all jams have stopped this disease patients not receiving Duplex regeneration ??IMG_9012.jpgIMG_9016.jpgIMG_9017.jpgIMG_9018.jpgIMG_9019.jpgIMG_9020.jpgIMG_9021.jpg
                  • 16083
                  [ATTACH=CONFIG]33140[/ATTACH][ATTACH=CONFIG]33141[/ATTACH][ATTACH=CONFIG]33142[/ATTACH][ATTACH=CONFIG]33143[/ATTACH][ATTACH=CONFIG]33144[/ATTACH][ATTACH=CONFIG]33145[/ATTACH][ATTACH=CONFIG]33146[/ATTACH]
                  check duplex unit harness connection
                  check for
                  24v into connection
                    • 16083
                    LOOK UNDER > USER MODE ITEMS > PRINTER SETTINGS
                    2-SIDED PRINTING OFF*, ON
                    An asterisk(*) indicates the default settings.
                    Duplexing Automatic Document Feeder (DADF-P2)
                    The imageRUNNER 2000 Series offers the Duplexing Automatic Document Feeder (DADF-P2) option only for the imageRUNNER 2022/2018/ 2018N / 2022N with
                    scanning speeds of up to 20 images per minute (ipm).
                    The DADF-P2 can hold up to 50 LTR-sized sheets and up to 25 LGL-sized or 11”x17” sized sheets.
                    The DADF-P2 comes standard with the imageRUNNER 2030i/2025i/2022i/2018i > "i" models.
                    Duplex Unit-B1
                    imageRUNNER 2018N / 2022N > is a option
                    (imageRUNNER 2022/2018 > is a option, standard with “i” models)
                    check for
                    24v into connection
                    • JPiek
                      • Oct 2014
                      • 435
                      I think he said the question was vaguely, not silly... He called is *own* question silly...
                      vaguely , as in - not clear- and i assume, not clear because we did not know if the copier did doublesided copies before or not. And that is quite different....
                      Johan
                      • cuongdigital
                        So let me ask if it was because of the default delete all duplex unit should not receive copies of it?
                        I have thoroughly probe the wire components and connections no matter what the exact cause is hardware or software ? that's all!
                        Thanks!
