iR-ADV C5235i Mail Box names not updated in printer driver
  • Jehuu
    • Nov 2009
    • 6
    I have ran into a problem with Mail box names stored in the printer driver for iR-ADV C5235i system software 21.06
    I have added new names to mail boxes, but in the driver, under store menu, the names list is not updated.
    What has not worked:
    Reinstalling the driver, same problem wether I use UFR2, PCL or PS3 language on W8
    Removing the driver, deleting from devices and printers folder.
    Removing the printer driver package from Print managment.
    Previously I have been under the impression, that inorder to get mail box names into the driver, DIAS was required, correct me if I am wrong please. But DIAS is only required for job accounting?
    Anyway pressing the "get device status" button in the driver does not produce a change.
    it seems to be a problem with the iR device - i installed, just a moment ago, UFR2 ver 20.90 on a new server 2008R2 that did not have any printer drivers installed, and only old mailbox names ( two of them ) are imported into the driver, not the new ones that I added recently.
    Did another test - deleted one of the old names, and pressed the get device status, the old name disappeared, but new ones did not appear in the list.
    Does anybody know a better solution, how to fix it, than formating the harddrive?
    This problem occurred with a cutomer device iR ADV C5030i in the firstplace, so I decided to take a closer look, with the device that I am using in our office.
    Best Wishes,
    Jehuu
  • Jehuu
    • Nov 2009
    • 6
    Re: iR-ADV C5235i Mail Box names not updated in printer driver
    I can edit the names on position 01 and 02, the change is also reflected in the driver, once i press "get device status"
