canon mp620 part found inside printer where should it go??
  • cjsmith
    • Aug 2025
  • teckat
    • 16083
    Re: canon mp620 part found inside printer where should it go??
    Originally posted by cjsmith
    [ATTACH=CONFIG]21335[/ATTACH][ATTACH=CONFIG]21336[/ATTACH]
    did u check the (open) rear cover
    what location found in ?
    any sign of broken on it ?
    • cjsmith
      [QUOTE=teckat;366961]did u check the (open) rear cover
      found inside on rail
      it ddi not seem to be broken100_3188.JPG100_3189.JPG100_3190.JPG100_3191.JPG100_3192.JPG100_3194.JPG last photo is where it was found
      • teckat
        • 16083
        [QUOTE=cjsmith;366970]
        it ddi not seem to be broken[ATTACH=CONFIG]21352[/ATTACH][ATTACH=CONFIG]21353[/ATTACH][ATTACH=CONFIG]21354[/ATTACH][ATTACH=CONFIG]21355[/ATTACH][ATTACH=CONFIG]21356[/ATTACH][ATTACH=CONFIG]21357[/ATTACH] last photo is where it was found
        is printer working ?????????????? 'if not what's going on other than this issue-
        looks like a spring inside
        • cjsmith
          [QUOTE=teckat;366990]
          [ATTACH=CONFIG]21364[/ATTACH]
          yes it is a spring inside of the black center
          the printer displays a C000 error when I turn on the printer ..cant do any thing with it
          • teckat
            • 16083
            Error C000 is a print head issue.
            Print Head Holder
            u think that piece has something to do with carriage movement
            -Open the printer and wait for the carriage to slide over
            -Remove the ink cartridges from the print head.
            -Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
            -Repeat this until there is no ink residue coming off on the cotton swab.
            -Once finished, allow to dry and replace the cartridges
            Turn on> see what happens
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • cjsmith
                Print Head Holder
                thanks to everyone that helped me on this site the mp620 printer is up and running again... part 100_3198.JPGwas broke off..
                but a little super glue worked,,,, don't know how long it will last but well see..
                a pain in the you know where to get it back in place... it rides on the rail in front of the print head to keep the print head in the right place
                thanks
                • teckat
                  • 16083
                  • cjsmith
                    [ATTACH=CONFIG]21370[/ATTACH]
                    duck tape would be my next choice
                    thank
