ltr feeds fine,but lgl jams just before entering fixing unit. Machine also feeds 2 sheets when 1 copy requested. trays are set properly. Jam code 203. Hope someone can help.
ir 3025 jamming with lgl paper
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Re: ir 3025 jamming with lgl paper
it's the shorter paper path location #1 that will not jam
Door Assembly
does legal jam if the lower right door is pushed on
check if black pins that the lower right door hooks onto are damaged or missing.The following image shows where each pin should be located on the Paper Pickup Assembly.
PS11 not responding quickly enough or getting stuck
--place xtra wrap on actuator spring
check**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Use a Captive(spring loaded) spring hook / all techs should carry one
I had a 3245 do this to me before...legal jam,two sheets fed,when it didnt jam it had a ripple in the paper. For me it was the sound damper for the pre-reg actuator. Scraped it off and problem went away. Installed new style damper when i went back. THIS WHOLE FAMILY OF MACHINES IS NOTORIOUS FOR STICKY DAMPERS...lower diverter on door,upper duplex diverter(there are 4 dampers..2 on end and 2 in behind).Comment
Hi Guys thanks for the suggestions, but nothing has worked so far and I an now desperate.I need to mention that at switch on, the machine immediately pulls paper from 2 trays and i get a stationary am at power on. Help!!!Comment
u power up printer & it starts to pick up paper
Paper Feeds From the Cassette During the Power Up Sequence
In this case below , the cassette 1 pickup solenoid (SL1) was excessively dirty and not properly functioning. The solenoid was cleaned and the machine returned to proper operation.
To check the solenoid operation refer to the following test:
1) Remove the cassette from the machine
2) Power on the machine
3) Press the paper size switch pictured below
4) Look at the paper feed section. The separation roller should turn counter-clockwise and the paper feed roller should NOT turn.
5) If the paper feed roller turns, check the SL1 solenoid. Solenoid SL1 should be energized and the cam rotating. Note: When the cam is rotating the paper feed tire will not rotate
6) Make sure the solenoid is cleaned and adjusted to let the cam rotate properly.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Hi teckat, a million thanks to you. I truly appreciated the info you gave concerning the operation of the solenoid. The solenoids were cleaned and tape used to replace the sticky material which impeded the movement of the armature. Once again respect to to you. God bless.Comment
