irc 2020i
  • ernesto
    • Oct 2011
    • 430
    irc 2020i
    Hi everybody
    I had to replace a black drum in IR ADV C2020i
    and it only has 27 k
    does anyone Know if this is common in this machines ?
    is there a solution ?
    many thanks
  • bipc
    • Sep 2009
    • 194
    Re: irc 2020i
    unfortunattly that series is known for alot of drum problems from that one to the infamous E020-XXXX errors, for now the solution is to keep changing them
    Life is a learning continuum...
      • 16083
      Re: irc 2020i
      Originally posted by ernesto
      Hi everybody
      [ATTACH=CONFIG]21485[/ATTACH]
      many thanks
      all goes by % of toner coverage on documents > & not volume
      NOTE==reminder
      When installing a new drum or developer assembly you need to run "ITB-Drum" under user setting.
      To run the user mode go into setting and registration / adjust maintenance / itb-drum.
      There is a user mode that is to be used after replacing the drum units on these machine.
      To see the user mode you first must enable it in service mode.
      Step one: In service mode change Copier / Option / Display SW / ITB-DSP set to =1
      Step two: Go into setting and registration / adjust maintenance / ITB-drum
      • shaqmut
        • Dec 2012
        • 5
        Re: irc 2020i
        yes hello!! i used to even on canon ir2018 i found bearing ball of DV get old and drum get same charge and failed very fast but on irc2020i drum their blade are very weak so u have to remove waste toner every 10k
        • bipc
          • Sep 2009
          • 194
          Re: irc 2020i
          and of course and like teckat said above the values for duration of toners varies according to percentage of coverage, the value given by canon is when considering a 5% coverage
