Noise in IR5055 only from Stack Bypass
+ More Options
Posts
  • ps/pcl
    TECH SPECIALIST
    • Jun 2008
    • 35
    [Jamming] Noise in IR5055 only from Stack Bypass
    Noise and jam in stack bypass in IR5055. THe problem is intermittent.
    Sometimes Five paper feed normally ,If huge noise occurs Jam 0101 occurs ,Paper feeds inside just for 5mm.
    Replaced Bypass Solenoid and Clutch. i have a suspect on Torquelimiter & One way clutch on pick uproller.
    Please Help.
  • Luther
    • May 2006
    • 682
    Re: Noise in IR5055 only from Stack Bypass
    change the rollers also
    • vigour
      • Aug 2010
      • 1038
      Two bearings in the pre reg drive assembly wear out, causing squeaking noise. XG9-0403
      Check the clutch too
